SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: Dash Lights 83' 380SL
Old 11-18-2013, 12:33 PM
mattrauch's Avatar
83' 380SL
Smile Dash Lights 83' 380SL
Hi, new to the forum, new owner of a 83' 380SL.
I'm having an issue where none of the instrument cluster lights or button lights in the console are working. None of the lights are responding to the dimmer, so I'm assuming the rheostat needs to be replaced or cleaned. Is there any reason to think this could be anything else? Thanks for the feedback.
Old 11-19-2013, 11:44 PM
lsboogy's Avatar
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
try spraying a little contact cleaner on it
I have had the same problem with my 75 230 - pulled the rheostat out, shook it a bit and sprayed some contact cleaner over it, and they worked - replaced rheostat and have had no problems since
Old 11-20-2013, 10:56 AM
mattrauch's Avatar
83' 380SL
I think I'll end up shorting the rheostat--I can't see myself wanting it any dimmer than max anyways.
Old 12-24-2013, 05:09 PM
artificer's Avatar
1981 W107 500SL
Check all the lights are working before re-installing the dash panel
+ it is a good idea to fit led bulbs to the indicator lights on the panel.
If the clock is not working it is an EZ fix by replacing the clock's 2 x 100 micro farad capacitors while you have everything out on the bench [cost <$1].
Quick Reply: SL/R107: Dash Lights 83' 380SL
