SL/R107: 1984 380SL Heater Problems
Hi All,
I have a 1984 380SL I need your help with:
- Heater does not work, nor does air come out when I put on the air.
- Replaced the Blower Motor and Climate Control Unit
- Oddly, at higher speeds there is heat and blowing from the front defroster when it is engaged on the control panel
- If you change from defroster at higher speeds it doesn't work from the other heater vents/outputs.
- Lower speeds, nothing works.
Any advise where to start or how to trouble-shoot?
Thanks,
Steve
Thanks,
Steve
