SL55/63/65/R230 AMG: Distronic Retrofit??
'06 E500, '99 ML430 and '07 SL65
Here's the cost breakdown to do it as I just got all the parts in prep of the conversion:
Here's a great link of how to: http://www.mercupgrades.com/Distroni...rticle-69.html
note that the 03-04 parts needed is different from 05+. 03-04 need a separate ECU. 2005+ have this built into the sensor.
Sensor: ebay- $150 (need to buy this used it is an outrageous price new)
ECU: ebay- $135 (need to buy this used it is an outrageous price new)
Distronic emblem for grill: $120 (from member on the board, but you can get an aftermarket grill with a distronic star in it for $150-$200 on ebay)
Bolt kit: ebay- $20 (available for $45 from huskerparts.com as these aren't on ebay often)
Wiring Harness: $106 from huskerparts.com
Dash/console switch that adjusts distance and replaces the ESP switch area: $74 from husker parts
So I'm in it $605 in parts and then will need to take it to the dealer to have the sensor aligned. Hopefully that isn't too brutal. I can do the computer coding myself since I have a star tool so I'll be able to save that expense.
My parts list was:
230-540-74-05 $16.80
001-540-63-17 $52.00
230.905-01-00 $69.60
+ the sensor which I found on eBay for ~$500. You can find them cheaper, but you want to make sure that it is the correct part #. So all in all for parts, it was $638.40
here's one for $219...
http://www.ebay.com/itm/Mercedes-R230-SL500-SL600-SL55-03-07-Grille-Grill-Glossy-Black-Star-Distronic-/361078237121?hash=item5411f0a7c1&vxp=mtr
there are also several others that have a distronic star on them that are 199 and 189
#33
the OEM one is only $475.02 with $11 shipping from husker parts too. They have the best price on most OEM mercedes parts.
http://www.huskerparts.com/parts/ind...&siteid=215771
#34
1 Post
06 S500 93 G350 08 Smart
Maybe any of you that have coded Distronic yourself with Star Developer can help me out here...
On my 2002 SL500 i have done the DTR (Distronic) coding, but after all the coding i have ESP error C151C "fault in CAN communication with ecu"
Any of you know if it is nessesary to change the settings in "Explizite Kodierung ME28 F3-Stand" Where the following options are available.
The car is coded as "4" now, but a change to "3" is tempting
1. R230_M113_E50_EU3EU4_NAG_ART_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
2. R230_M113_E50_EU3EU4_NAG_VGB_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
3. R230_M113_E50_EU3EU4_NAG_ART_ABC_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
4. R230_M113_E50_EU3EU4_NAG_VGB_ABC_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
The other coding i have done is this:
ADDING DTR TO EZS(ZGW) 1
control unit groups
body
EZS
control unit adaptions
read coding and change if....
Distronic (present/ not present)
ADDING DTR TO EZS(ZGW) 2
control unit groups
body
EZS
Development data
control unit adaptions (Variant coding)
Varcode_Description
Abstandregeltempomat "vorhanden/nicht vorhanden" (In English Distronic "present/not present)
UNLOCK ME 2,8 SFI FOR PROGRAMMING
control unit groups
drive
ME 2,8 SFI
development data
actuations
complete index of actuations
steuergerät entriegeln -> confirm
ADDING DTR TO ME 2,8 SFI
control unit groups
drive
ME 2,8 SFI
development data
variant coding
Implizite codierung
"Bandende, ART (Tempomat nicht aktiv)" (In English Distronic (Cruise control not active))
ADDING DTR TO INSTRUMENT CLUSTER
control unit groups
information and communication
ICM - instrument.....
special equipment
RESET DTR MODULE
control unit groups
Drive
DTR distronic
ADDING DTR TO LOWER CONTROL PANEL (LCP)
body
LCP
development data
control unit adaptions (download)
programmieren des funktionsverhalten des jeweils verbauten ART-Steuergeräts (In English Type of Distronic: two box early model, or one box late model)
F3 Two box
Anything i am missing to get rid of that ESP error ??
Regards Per
control unit groups
body
EZS
control unit groups
body
EZS
Development data
Varcode_Description
control unit groups
drive
ME 2,8 SFI
development data
actuations
control unit groups
drive
ME 2,8 SFI
development data
variant coding
Implizite codierung
control unit groups
special equipment
RESET DTR MODULE
control unit groups
Drive
DTR distronic
body
LCP
development data
F3 Two box
Regards Per
#35
2002 Mercedes-Benz S320 (W220)
ESP Module
control unit adaptations (or it could be in actuations)
There should be a menu called something like "unlock version".
Once you click on that, the ESP unit resets to the configuration of the CAN BUS and the ME-ECU version coding.
Hope this works for you too
#36
1 Post
Got it to work a few days ago..
Changed the ECU Coding in "Explizite Kodierung ME28 F3-Stand" to the ART version.
All is good, it works like a dream.
There's no coding done in the ESP module on early R230s
But thanks for the tip anyway...
