SL55/63/65/R230 AMG: SL55 AMG wheel information
Old 08-30-2011, 02:33 PM
C and C Media's Avatar
SL55 AMG
Hi
I am looking to upgrade my wheels on the 2004 SL55 AMG. What offset, centre bore size and PCD are the standard wheels? so I know what to spec when looking for the new wheels
Steve
Old 08-31-2011, 10:53 PM
Stevant's Avatar
2005 SL55 AMG
ISSForgEd wheels
I purchased my ISSForged wheels for my SL55 from Rafic at Wheels Performance. He knew exactly what size wheels and tires would work on my car. In fact they are made specifically for the SL and sit perfect with the wheel wells. Take a look at my vehicle if you like. He has many companies to choose from but he knows what fits well.
Good luck!
Steve
Old 09-01-2011, 10:07 AM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
just make sure the wheels are for a r230 and that they are hub centric
Old 09-01-2011, 06:08 PM
davidliu68's Avatar
2006 SL55 AMG
I am also looking to upgrade the wheel. I like the ISS FORGED - COMPLEX-5. is 20" diameter too big for SL55 AMG. I am worry about if it will touch the body as you turn left and right.
Old 09-01-2011, 06:55 PM
Stevant's Avatar
2005 SL55 AMG
Iss forged complex 5
I was going to get the 20" also but wanted a better ride so decided to go with the 19" myself. So glad I did. I have 285/30/19 in the rear and 255/35/19 in the front. The offset they use is perfect for the car. I have a 10" wheel in the back and a 9" in the front. The 19" wheel gives you a little more sidewall and provides a more comfortable ride. I lowered the car and to me cannot tell the difference between the two wheel sizes. My wheels never touch or rub. Just my .02$
Good luck!
Take your time and choose wisely.
Old 09-01-2011, 07:51 PM
cal1's Avatar
SL55, ML500 & Acura TL
You can do 20s, but as stevant says, the ride is somewhat compromised. Rough rodes are hell on them too. I live in the land of the giant pothole and refuse to change out my stocker 18s because even the 18s get tweaked with all of the rough roads in my area. I could not imagine what the roads would do to 20s. If you are wondering, yes, I miss as much rough roadway as I can. I even take different routes to places based on the roads. I was once pulled over by a policeman. He thought I was drunk. I was just dodging potholes. He was really cool about when I told him.
Old 09-01-2011, 10:37 PM
Auraraptor's Avatar
Front offset ranges from 28 to 35 for the front, 30 to 40 in the rear.
Standard Benz bore in the mid 60s.
Old 09-02-2011, 07:36 AM
threeMBs's Avatar
Only MBs - the best or nothing
Mercedes Center Bore is 66.56mm. PCD is 5x112.
For aftermarket wheels, you can go as low as mid teens (which is much more aggressive than stock mentioned above) offsets both front and rear depending on wheels' width.
Quick Reply: SL55/63/65/R230 AMG: SL55 AMG wheel information
