SL55/63/65/R230 AMG: 06 SL55 Clicking sound when Turning the steering wheel Backing out of the Driveway.
Old 12-19-2014, 09:26 AM
mrsebastian's Avatar
2006 SL55 AMG
Hey guys,
Im experiencing a clicking sound as I'm turning the wheel to the car at low speeds when backing out of the driveway or pulling into a parking space. The sound is coming from close to the wheels, axel, control arm area..... Does anybody know what this might be from? I'm dying to know so I could get this fixed because the sound is quite annoying. Any help would be great. Thanks!
Old 12-19-2014, 09:47 AM
SL55_Forever's Avatar
3-pointed star
Originally Posted by mrsebastian
Hey guys,
Probably front thrust arms needs replacement - about $1000 parts and labor.
Front thrust arm and control arm bushings can crack and sometimes tear completely. If this is not repaired quickly, damage to the front subframe unit will occur, which is very expensive to repair. Updated control arms (that prevent damage to the subframe when the bushings wear out) are available.
Old 12-19-2014, 06:05 PM
SteveO_TT's Avatar
2005 SL65
https://mbworld.org/forums/sl55-amg-...ring-sl65.html
Old 12-20-2014, 07:49 PM
fxrs1955's Avatar
2014 SL550
This
Old 12-20-2014, 08:24 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
Yeah that lol, a lift makes it easier ,it's an annoying sound
Old 12-21-2014, 11:39 AM
cal1's Avatar
SL55, ML500 & Acura TL
I have a nice clear PDF with pictures of the cracking Noise when Steering Left or Right DTB. I pasted it below, but only got the text. If anyone wants the PDF, please PM me with an email address and I will send it.
By the way, do not let an Indy or Dealer tell you the rack is bad.
DTB Date: June 4, 2009
Order No.: P-B-46.20/60b
Supersedes: P-B-46.20/60a dated January 26, 2009
Group: 46
Revision History
Revision Date Purpose
b 6/4/09 Damage Code Revised
a 1/26/09 Applicable Models Updated (230.470 added)
- 12/21/07 Initial issue
SUBJECT: Model 230.470/471/472/474/475/476/476/479, All Model Years
Cracking Noise when Steering Left or Right
If you receive customer reports of cracking noise when steering left or right at low speeds just before limit
stops, noticeable also at steering wheel this may be caused by lost preload and settling or poor contact
surface between diagonal struts (Figure 1, 1) or the reinforcement plate (Figure 1, 2) and the front axle
carrier. The cracking movement is noticeable on the steering gear on a stationary vehicle with wheels on
the ground when steering to left or right. To resolve it is necessary to clean bolted contact surfaces
between diagonal struts, reinforcement plate and the front axle carrier.
Note: The steering rack is not the cause of the cracking noise. Do not replace steering rack!
Note: The below procedure must be performed on a drive-on lift. Vehicle must rest on wheels.
1. Remove lower engine compartment paneling. Refer to WIS document AR61.20-P-1105R.
2. Unclip cover on diagonal struts at front.
3. Remove diagonal struts (Figure 1, 1).
4. Check and clean thoroughly contact surfaces if necessary on the struts and on the front axle carrier
to ensure firm connection when attached.
5. Remove reinforcement plate (Figure 2, 2) from front axle carrier.
6. Check and clean contact surfaces if necessary on the plate and on the front axle carrier to ensure
7. Install reinforcement plate (Figure 1, 2) on front axle carrier. Torque retaining bolts to 12 Nm. Refer
to BA62.30-P-1006-01A entry in WIS doc BA62.30-P-1000-01A.
This bulletin has been created and maintained in accordance with MBUSA-SLP S423QH001, Document and Data Control, and
MBUSA-SLP S424HH001, Control of Quality Records.
© 2009 Mercedes-Benz USA, LLC. All rights reserved. Reproduction or translation in whole
Mercedes-Benz Canada, Inc. or in part is not permitted without authorization from the
Dealer Workshop Services publisher. Printed in U.S.A.
www.MBUSA.com 1-800-FOR-MERCedes
www.startekinfo.com
8. Install diagonal struts (Figure 1, 1) and torque retaining bolts to 70 Nm. Refer to BA62.30-P-1004-01A entry in WIS doc BA62.30-P-1000-01A.
9. Reinstall strut covers
10. Install lower engine compartment paneling. Refer to AR61.20-P-1105R.
Figure 1 P-B-46.20/60 Note: The following allowable labor operations should be used when submitting a warranty claim for this repair. This information has been generated on June 4, 2009. Please refer to Netstar �� Star TekInfo �� Star Time for the most current labor time allowance.
In Case of Warranty
Operation: Contact surface of diagonal struts, clean (02 3960)
Damage Code
Operation Number
Time (hrs.)
Model Indicator (s)
52A02 38
02 3960
0.9 hrs.
R1, R2, R3, R4, R5, R6, R7, R8
2 P-
Old 12-22-2014, 06:06 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
clicking wheel
What type of wheel do you have? If it is a two piece AMG similar to standard wheels on a SL65 it is usually due to cracked wheel or loose wheel screws. I have had two wheels go south and both were due to defects in the wheel. They both clicked each time the affected area rolled on the ground.
Old 07-31-2017, 08:05 PM
mrwest420's Avatar
sl55
Need PDF
Hi Please send me PDF to ted.suh627@gmail.com.
Group: 46
Revision History
www.startekinfo.com
In Case of Warranty
Damage Code
Operation Number
Time (hrs.)
Model Indicator (s)
52A02 38
02 3960
0.9 hrs.
2 P-
Old 06-28-2021, 04:52 AM
diegodeglana's Avatar
2006 sl500
Email me pdf clicking noise. Diegodeglana@gmail.com
Group: 46
Revision History
www.startekinfo.com
In Case of Warranty
Damage Code
Operation Number
Time (hrs.)
Model Indicator (s)
52A02 38
02 3960
0.9 hrs.
2 P-
need pdf for clicking noise
diegodeglana@gmail.com
Quick Reply: SL55/63/65/R230 AMG: 06 SL55 Clicking sound when Turning the steering wheel Backing out of the Driveway.
