SL55/63/65/R230 AMG: Question - Ticking sound - steering - SL65
Old Jul 31, 2010 | 10:21 PM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
Question Question - Ticking sound - steering - SL65
When I turn the steering wheel all the way either way it makes a distinct tick sound a few seconds apart about 3 times from outside of the car and underneath..does not seem normal.........any ideas oe experience as to what this may be? any theories helpful..power steering pump, steering rack, etc???
Old Aug 1, 2010 | 12:07 AM
EXECMALIBU's Avatar
SL65, 427 COBRA (CSX-3127)73 911S, 246GTS (DINO SPYDER), CORNICHE,1962 PORSCHE TWIN GRILLE ROADSTER+
There is a DTB about this... It is the cross brackets...
DTB referring to squeaking cracking sounds... The cross brackets under the suspension need to be removed...
If you drive your SL65 fast the V12 engine could fall out!
Just Kidding!
They remove the cross brackets clean and lube the area around the bolts and reinstall (about 1 hr). My tech spayed under-coating on them where they bolt on...
Old Aug 1, 2010 | 07:52 AM
abiazis's Avatar
Smile DTB
Thanks.....thought it was something extraordinary. Do you know what causes the sound by any chance?
Old Aug 1, 2010 | 08:25 AM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
Wow. I am so glad you posted this. My car also makes the loud click noise when turning the wheel while trying to park. Any chance we could get a couple of pics of these cross braces. And the locations of where to lube.
Old Aug 1, 2010 | 08:35 AM
abiazis's Avatar
Wink DTB
If we could locate a copy of the DTB, it probably would help the most....I do not have access to them.....
EXECMALIBU provided great info....on top of things!! THX again...
Old Aug 1, 2010 | 01:14 PM
EXECMALIBU's Avatar
DTB FOR CRACKING NOISES...
DTB
Attached Thumbnails Question - Ticking sound - steering - SL65-dtb-cracking.jpg
Old Aug 1, 2010 | 03:59 PM
abiazis's Avatar
Thanks for DTB
That was nice of you to post the document....really cool......best regards from those of us with the issue..........)
Old Aug 2, 2010 | 07:35 AM
NikleinR6's Avatar
Awesome.. Thanks for posting the document.. Any chance we could get also get the doc that has the figures in it for visual reference..
Nick
Old Aug 2, 2010 | 03:30 PM
abiazis's Avatar
Smile Updated document # - copy needed if possible
I found out updated document number is P-B-46-20/60b....sent to dealers June 2009
if anyone can forward originally sized document via email - biazis2@charter.net, that would be helpful..........thanks.........
Old Aug 11, 2010 | 11:15 AM
abiazis's Avatar
Smile Bulletin from warranty company received
Fixed for $ 139.00.......per bulletin.........no new parts involved, disassembly, cleaning and lubing......ticking/cracking sound gone...
Old Aug 11, 2010 | 12:11 PM
NikleinR6's Avatar
Could someone please snap some pics of what needs to be removed/lubed/and reinstalled.
My car sounds terrible when i parallel park. Or turn the wheel anytime while sitting still for that matter..
Are there some suspension diagrams i can use as a visual reference??
Thanks in advance..
Also, what cost 139.00??
Nick
Old Aug 11, 2010 | 04:29 PM
NikleinR6's Avatar
I stopped by the dealer and got a print out of the DTB. I will post it in a couple of days when i get my scanner online..
The diagram helps alot...
-Nick
Old Aug 11, 2010 | 06:52 PM
abiazis's Avatar
Wink Cost to repair - labor
The cost of 139$ was for labor....car has to be on rack where wheels bear weight of the car.........some disassembly of underbody before getting at diagonal struts where bolts are cleaned, lubed and retorqued........ about a hour to deal with..........I have a picture but can't extract from document....send me your email via PM if u would like and I'll send u what I have....Star Bulletin that I secured did not have photos.........
Car is QUIET now on turning steering wheel all the way at rest or very low speeds - backing out of driveway, etc...
Old Sep 8, 2010 | 12:26 PM
NikleinR6's Avatar
Fixed the issue. It just required jacking up the front, removing the under-paneling, removal of a few bolts, and adding some thick lube...
Here is the DTB i promised..
(i tried to clean it up a bit)..
Old Aug 5, 2014 | 12:37 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
I have the clicking noise in my 2003 SL55. Having the work done today.
Old Aug 5, 2014 | 10:10 PM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
wow! thank you for this, this also happens on mine, i didn't pay much attention thought it was normal coz it happened all the time
Old Aug 6, 2014 | 04:48 AM
fxrs1955's Avatar
2014 SL550
This is a very easy fix. I had the tranny out of mine and cleaned and put anti seize on all the mounting points, problem solved.
Old Aug 6, 2014 | 03:44 PM
Benz-O-Rama's Avatar
Nice find. Thank you. Needed this...
Old Aug 8, 2014 | 04:40 PM
abiazis's Avatar
Mine is still fixed after several years….I think my indy used a new set of bolts to make sure it doesn't come back……...
Old Aug 12, 2014 | 09:24 AM
rsr911's Avatar
Problem solved $135.00 Not a bad steering rack.
Old Dec 1, 2015 | 05:29 PM
walterwhite's Avatar
2008 Ducati 1098 2003 SL55 AMG
Smile
Hi All, so my SL55 had the issue addressed in the DTB in this thread. I could have taken it to the local Mercedes dealer and had them fix it but I decided to tackle it myself for fun as I had some free time over the holidays.
I do not have a lift in my garage. And since this fix requires lifting the vehicle by the wheels/tires and not just with floor jacks I had to figure out how to do that. A quick Google search yielded a Turbo Diesel site where a guy posted a thread detailing how he built wooden blocks to lift his car. I followed his guide and built 4 blocks to lift the SL. Each block is 24" long and 16" wide. Each block has two layers/stages. The first stage is 8.5" tall and can be used on it's own. If you need additional height you can put on the second stage and that'll give you a total of 14" of height (enough to pull a tranny out). I tested the blocks out on another less expensive car that I have to make sure they held and sure enough they didn't budge one bit. The design is solid and very safe to use. One thing I'm missing is a block for my floor jack. I wasn't able to use the second stage to get to a total of 14" because my floor jack wasn't tall enough. I was still able to complete the fix using the 8.5" blocks (I did the modification he recommended and added 1.5" to the stage 1 block so that I'd get 8.5" instead of his original design's 7").
The SL DTB fix was easy to do. I took my time and cleaned all of the bolts and parts that had to be removed thoroughly. I torqued everything down and reinstalled all of the under panels. I've driven my SL 100 miles so far and the squeaking is completely gone. This car kicks ***.
Wooden Blocks Tutorial: http://www.myturbodiesel.com/wiki/wo...o-jack-stands/
- Walter
Pics from the Turbo Diesel Wooden Block Build Thread:
Stage 1 Wooden Blocks ~7" Tall (pic doesn't show mod to get to 8.5" which is adding an additional 2X4 set)
Stage 1+2 Wooden Blocks ~14" Tall
Old Dec 3, 2015 | 03:28 AM
ALEN35's Avatar
2007 sl65 amg
bump
Old Dec 3, 2015 | 01:57 PM
kk100's Avatar
CL65
Just seen this! I have been looking since while about the loud noise/click when I do full steering lock - the only thing is I have a W 215 CL65 so does anyone know if the fix also applies to it? Thanks for any help
Old Apr 4, 2021 | 07:49 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Old thread but I wanted to say THANK YOU for sharing this DTB and fix to that annoying creaking/clicking sound (when turning at low speeds) on my 2004 SL55 with 70k miles!
The repair steps in the DTB doc and what others shared here are what you follow and this absolutely FIXED my issue and the car sounds/feels like new again with ZERO annoying clicking noise!!
The most time consuming part of this is getting the front of your car up on jacks and then removing the 3 splash guards. The 2 diagonal struts connect in a V shape and require a T30 torx bit to tighten the 5 total bolts which includes 1 bolt that connects the diagonal struts together and then 4 other bolts (2 on each side) to connect the middle of the diagonal strut and then the very end of the strut. What was surprising is 3 of my bolts holding the diagonal strut in place were super loose and required zero effort to remove which is the cause of the noise since the diagonal strut connect point was very loose as were the next 2 middle bolts. I think you could honestly skip the steps of removing the struts, cleaning, lubricating and just use the T30 torx bit to tighten those 3 bolts to 70nm torque and will fix your problem.
Anyway, just wanted to share my experience and thank those for sharing this fix!!! 70k miles and she drives like new and no clicking sounds!!
2004 SL55 AMG - 70k miles - stock
I
