SL55/63/65/R230 AMG: Transmission smoke when hard accelerating.
Old 02-01-2015, 08:30 AM
JadAwada's Avatar
SL55 AMG
Well, I know the smell is of the transmission fluid. And when I park after the car smokes, red fluid can be noticed under the car (not a very big amount though).
When the car is being driven easily all is fine, but when hard accelerating, and when going mountain roads, the transmission throws fluid, and it starts smoking.
I installed an external transmission cooler to make sure it's not a problem with the oil. but still the car does the same symptom, what do you suggest?
Is this a symptom of the torque converter?
Old 02-01-2015, 08:55 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Sounds like you have a leak somewhere and under high pressure it seeps and with the higher temperature it starts to smoke. Find the leak
Old 02-01-2015, 10:40 AM
JadAwada's Avatar
SL55 AMG
Well not really, there's no leak under the car. Even when its turned on. This symptom only occurs under hard acceleration, there seems to be a problem with the transmission. I really don't know what exactly is happening but its an unknown symptom.. I wish anyone which experienced this problem can help.
Old 02-01-2015, 10:48 AM
fxrs1955's Avatar
2014 SL550
Check your front pump seal.
Old 02-01-2015, 11:01 AM
JadAwada's Avatar
SL55 AMG
the oil is directly under the transmission oil pan. At first the workshop assumed that the oil is above the maximum level, but when checked, it showed that the oil level is fine. Will check the pump seal.
Old 02-02-2015, 03:29 AM
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
+1 for pump seal,,
also check the pan gasket & pilot spacer as well, those most common leaks in 722.6...!
ZAYED,,
Quick Reply: SL55/63/65/R230 AMG: Transmission smoke when hard accelerating.
