SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Light-red Fluid Leak from beneath gas tank
Old 08-08-2016, 03:41 PM
Pecher's Avatar
Merceder-Benz SLK 200 R170
Hello,
can some advise what it is - Light-red Fluid Leak from beneath gas tank. Today has seen a puddle around 7cm beneath gas tank and dripping fluid from mid of gas tank from bolt. the fluid is little sticky with almost no smell, light read/transparent.
Appreciate some advise..
Old 09-01-2016, 06:51 AM
El_Toro_33809's Avatar
2003 SL55; 2001 SLK320; 2005 C240
I thought transmission fluid was typically red. Could it be wicking back towards the fuel tank area when you are driving?
Tim
Old 09-01-2016, 07:10 AM
B2FiNiTY's Avatar
'16 GLC300
Sounds like transmission fluid. Trace it back to the middle if you can.
Quick Reply: SLK/R170: Light-red Fluid Leak from beneath gas tank
