W210 Mercedes E55 AMG Project
Old 02-01-2016, 02:43 PM
  #251
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
That was AWESOME Jim, Thankss for your time visiting us, at your service always,,
that day was soooooo Nice with you & captain Wxxxxky..
ZAYED,,
Old 02-01-2016, 03:32 PM
  #252
M3RC3D3SE55AMG's Avatar
Mercedes-Benz E55 AMG (W210)
ZAYED,,
I need to come and check out your new kit!
Old 02-01-2016, 03:51 PM
  #253
cm60k's Avatar
Sure, why NOT..
Old 02-07-2016, 06:52 AM
  #254
Had this t-pipe split on me today. It's taken the car off the road, as its part of the coolant system and I don't fancy a seized engine. Should have my custom fabricated metal replacement made and fitted by the morning though.
Old 02-08-2016, 05:28 PM
  #255
Problem solved. Had a new t-pipe machined to spec, which has replaced the broken and seemingly obsolete plastic unit. Works perfectly and won't need changing again, ever. It's finished with a touch of heat resistant black paint.
Old 02-08-2016, 05:33 PM
  #256
cm60k's Avatar
Fast & Excellent jooooooob Broooooooooooo..
ZAYED,,
Old 03-01-2016, 04:09 PM
  #257
Tanderso's Avatar
2002 Mercedes-Benz E55 AMG
Hey M3RC3D3SE55AMG have you had a chance to dyno this beast yet?
Old 03-19-2016, 03:47 PM
  #258
sammyfabio's Avatar
W210 E430 2001, ML350 2011 AMG, CLK200 W209
awesome man, great thread
i admire your work and your time putting all of this info in one place, you made my passion for e55 w210 100 times more by reading all of this and knowing that someone in Dubai has gone through what I'm about to do, I'm planing to buy an e55 japan import 2001 this month and then my journey will start just like yours did, keep us updated man and thanks a lot again
Old 03-20-2016, 12:45 PM
  #259
That's great! Anything you need, let me know! I have contacts for everything from servicing to parts - and reliable contacts too.
If you private message your number I'll give you a call to just touch base and throw some information back and forth with you.
Congratulations on the W210 purchase as well!
sammyfabio (03-20-2016)
Old 03-25-2016, 09:42 AM
  #260
Still haven't got around to getting the car onto a Dyno for diagnostic runs, but have had time to get online and order what I have found to be the only full coilover suspension system for the W210.
The system is engineered by PB Brakes and I'm seriously looking forward to getting it installed. Dan (owner of PB Brakes) is one very helpful individual - and I recommend PB Brakes be checked out by all W210 owners in regard to braking and suspension system upgrades.
Old 03-25-2016, 09:14 PM
  #261
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
How do you plan to tune the car?
Steve
Old 03-25-2016, 09:57 PM
  #262
Steve
It's already tuned, but I want to tweak and optimise it further.
Old 03-26-2016, 05:01 PM
  #263
turbo1k's Avatar
What software did you use to tune the car?
Steve
Old 03-27-2016, 04:58 AM
  #264
Steve
Hi Steve,
I'll find out and update you.
turbo1k (03-27-2016)
Old 04-01-2016, 04:55 PM
  #265
ddb
ddb's Avatar
2002 E55
M3RC3D3SE55AMG,
Thanks for posting this information. I'm interested in this setup and have some questions since you've already been in contact with PB.
Are the pillow ball mounts available for our cars? If so, are you getting them? Did you go with the recommended spring rates or specify a custom rate? They state they have one of the most comfortable coilovers on the market, which is what I want. I know this system has a lot of adjustability (30 damper settings plus 50mm of height adjustment). What kind of ride are you hoping for and have they assured you it is attainable? My concern is if the ride will be soft enough when set on the softest setting.
Thanks for your time and I'm looking forward to your thoughts after the install.
ddb
Attachment 327565
Old 04-02-2016, 12:56 PM
  #266
Originally Posted by ddb
M3RC3D3SE55AMG,
ddb
Thanks for your message.
Let me get the kit installed and I'll update you on everything I find in regard to setup versatility.
The pillowball mounts are not applicable on my car because I don't have camber adjustment as stock, as is the case with most 210's, if not all - right?
In regard to spring rate, I did indeed go with the PB Brakes recommended spec. Anyone who's spent the time and money in R&D for a system specific to our cars - I'm following their advise to the letter.
This is the point I kept coming back to when opting for this kit. It's not a generic system tweaked to fit a 210. It's a fully developed system strictly for the 210.
Old 04-03-2016, 01:26 PM
  #267
The PB Brakes coilover kit arrived the day before yesterday, but I didn't have chance to collect it until today. Fitting is set for tomorrow morning - with a new set of rear wheel bearings as well since they decided to go today.
Old 04-05-2016, 06:40 PM
  #268
Tall Giraffe's Avatar
2001 E55 OMG
Cant wait for these findings! Wonder if we could do a group buy? Id be in!
Old 04-05-2016, 07:56 PM
  #269
cm60k's Avatar
This car is Gorgeous, as well as the "driver"..
should to come to see it MaaaaaaaaaaaaaaN..
ZAYED,,
Old 04-06-2016, 01:01 PM
  #270
I can arrange a discount on the kits for anyone interested actually. I just did exactly that for a friend in California who drives a 2002 W210.
Old 04-06-2016, 01:02 PM
  #271
ZAYED,,
I'm coming to see you after next weekend Zayed.
It's time we saw each other for a good catch up!
Old 04-06-2016, 01:14 PM
  #272
PB Brakes coilover install update.
Old 04-06-2016, 05:32 PM
  #273
2001 E55 OMG
That would be great! I anticipate your thoughts on the kit first but it looks like its a great solution for the price, ride and performance so far. Given your additional power mods, Im sure you can give it a good test.
Did your friend have any feedback on the kit?
Old 04-06-2016, 09:16 PM
  #274
illest's Avatar
4 matic
looks similar to the ksport 'coilover' kit (but the price is better)
Old 04-12-2016, 05:32 PM
  #275
kyle210's Avatar
Current: 00 e55 6 speed wagon, 99 e55, 00 ml55, 02 m3, 83 ur quattro
I do have feedback actually. I have had these on my car for about 2 weeks. I was previously on vogtland springs cut one coil all around and #1 spring pads. I loved the height and was able to maintain the same height with these coilovers which is about 3 inches lower than stock all around. They ride amazing and are incredible when cornering hard even being this low. I have high performance summer tires and love to drive the car at its limit through the canyons and these coilovers get the job done. Only complaint I have is that under 40mph the fronts make a little bit of noise and it sounds like they are under quite a bit of stress but it is most likely due to the fact that I am so low. It's not the worst thing in the world. For the price honestly theres no way you will be able to find something better
Quick Reply: W210 Mercedes E55 AMG Project
