Hvac bulb
Hvac bulb
Does anyone know the style of bulb for the hvac system? Mine burnt out, I pulled it but the only numbers on it are the watage and voltage. I also need a stock ashtray as mine is missing as well as the bulb and socket for the light up ring around the lighter. Any help is greatly appreciated.
00 C200 & 00 C55 & 06 SLK55
If you mean climate control bulb, it's 1.2W,
*there are 2 style, one with white bracket & one without bracket, OEM #: "002 544 02 94",
or
*you can also use LED canbus Error bulbs:-
http://www.autolumination.com/py24w.htm
ZAYED,,
or
ZAYED,,
