Is this Drone!????
Old Aug 31, 2014 | 09:10 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Is this Drone!????
Hello everybody,
When I bought the car, the resonator was already replaced with 2.5 straight pipes, there was Bass but not much. However, I replaced the rear cats with a 2.5 X-pipe with time the car is sounding more and more glorious. Problem is, the cruising noise became annoying with time. I'm not sure if It's drone TBH.
I attached a link to the vid. It only occurs while cruising starts at 95Km/h and is very audible at exactly 117Km/h ( Please use a headphone or a good external speakers with good low end playback)
https://www.youtube.com/watch?v=-Pmm...ature=youtu.be
Old Sep 2, 2014 | 02:21 AM
benzokirk's Avatar
Veteran: Air Force
2008 E63 AMG, 2018 VW Golf R
I'd say so...
Originally Posted by Solo wing
Hello everybody,
it certainly sounds like it to me, however, my car doesn't sound like that now, and I never heard the "drone" sound often discussed here. I often wondered what was meant by that term, but listening to what you're experiencing - that sound would fit. I always imagined it to be an evenly sounding hum, but that pulsating sounds closer to what guys here talk about.
I wonder if the length of the straight pipe and the exact position of the x-pipe matters? I've heard that the x-pipe should be installed as close to the engine as possible (??)
Old Sep 2, 2014 | 12:33 PM
Fabio D's Avatar
210 55
Yes! as close as possible to the heads is the best place to install
Sounds good my friend! we need some floored to hear it a little more hahahah
Fabio Daniel
Old Sep 3, 2014 | 12:00 AM
Solo wing's Avatar
True, the word "drone" is not mentioned here a lot, but in the W211 and the C63 sections you'll find a few threads.
It sounds like an even hum and only pulsates when I lift my foot from the pedal. I have a 2.5 Magnaflow X-pipe which is in place of the rear cats.(as close to the engine as possible).
Old Sep 3, 2014 | 12:07 AM
Solo wing's Avatar
Fabio Daniel
Hey Fabio, I have the X-pipe installed in place of the 2nd cats, but when I'm driving on the highway I hear an unwanted noise (drone-much bass), very annoying and I'm searching for solutions.
Cheers.
Old Sep 3, 2014 | 07:32 AM
Fabio D's Avatar
210 55
Mate you can install some stainless steel bottles (little resonatos) in place of the factory resonator (do not move the x-pipe cause you have it installed in the best performance place) but i think, installing some little resonators you will solve the drene
Fabio Daniel
Old Sep 4, 2014 | 10:07 PM
benzokirk's Avatar
Veteran: Air Force
Okay, so the placement is good...The even hum I could live with, it's the pulsating that I'd like to know if you're able to alleviate. Let me know, because when I remove my cats my set up will be the same as yours, so I'll wait to see what you come up with.
Old Sep 26, 2014 | 03:52 PM
Solo wing's Avatar
The strange thing I noticed is that the drone changes with outside temp, the hotter it becomes the louder it gets!?!
also I believe that drone is generated at the end of the exhaust section after-resonator before-muffler.
I have the x-pipe placed as close to the engine which gives me better scavenging but the drawback is sound waves resonate at the straight section after the x-pipe.
I wonder what will occur if I put a second x-pipe before the muffler, like some c63s with the Double XX X-pipe by GT PRO Performance Tuning.
For now I might soundproof the trunk, spare well area and see what happens.
My last option is to install the bottle resonators.
