Anyone want to donate a 55k motor in the name of science?
Old 04-23-2014, 10:05 AM
blackbenzz's Avatar
haters crazy
After my motor blew 2 days ago I think I found the limit of what a 55 NA block can handle. Rod snapped and lodged a piston in the cylinder. The rod made a huge hole in the bottom of the block and all the way up both sides of the block. It puked oil onto the tires goign 100mph down the track. Luckily I was able to keep it out f the wall. I will get better pictures after I pull the motor out in the next couple days.
I'm probably going to do a full build this time because I don't want to risk my life again with a stock NA 55 block. 10.09@138 was traction limited best time. 6.29 60 to 130 on bias ply tires on flat surface and best trap was 138.71.
Now what would be interesting is to drop a stock 55k block in it with the exact same mods/setup and see what happens. I don't want to spend that kind of money just to see the limits of a 55k block. If someone has one laying around and wants to donate it in the name of science I will throw it in and head back to the track in the next couple weeks. Just thought I'd throw the idea out there
Old 04-23-2014, 11:29 AM
Denroll's Avatar
'06 E55
Not a block, but I have a set of heads sitting around down in Houston, just waiting for someone to get them ported.
Old 04-23-2014, 12:31 PM
blackbenzz's Avatar
haters crazy
Thanks. I will start pulling the motor tonight and tear down the motor this weekend. Will post pics along the way when I remember to stop and take pics lol. If I got reallly lucky the heads are ok and the valves are just bent in that cylinder. Not likely though. These heads were ported
Old 04-23-2014, 01:18 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Damn brotha!
I've got a running long block minus cams but number 8 probably has ringland issues. I was going to get crazy with it but I'd let it go for cheap if you can't find anything else.
Old 04-23-2014, 01:40 PM
Mitch Detailed's Avatar
2006 E55 AMG Kompressor
What is the analysis on why the engine failed? revving high/fatigued rods? more power than the rods could handle? any detonation or excessive timing?
What are your options for beefing up the bottom end? I read on eurocharged's site about how they got darton to sleeve the block.
Worthwhile investment for rods, pistons, and sleeves?
Old 04-23-2014, 03:05 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Spectacular carnage
Old 04-23-2014, 04:05 PM
blackbenzz's Avatar
haters crazy
Originally Posted by chiromikey
Damn brotha!
Thanks, I will keep that in mind
The motor blew about 48 hours ago. I have not had time to tear it down yet and inspect it. I have looked at logs.
I've had a block at Darton for almost 2 years now lol. It might be time to pull the trigger. I'm not doing anything until I pull the motor and tear it down and assess damage.
Originally Posted by HeissRod
Spectacular carnage
I was actually smiling when I saw it on the lift. I was thinking that is so badass! Can't wait to pull it out and make a table out of it!
Old 04-23-2014, 04:28 PM
I'm interested in the cost of block sleeving services if you do pull the trigger. :click click boom:
Old 04-23-2014, 04:30 PM
blackbenzz's Avatar
haters crazy
I forget the exact number but it wasn't cheap! I will let you know when I check on pricing again
Old 04-23-2014, 04:34 PM
justinwrock's Avatar
Ducati
You accepting donations?
Old 04-23-2014, 05:05 PM
Thericker's Avatar
V12-Biturbo
Damn... That was fast... Literally & figuratively!
I was thinking exact same thing, luv the Spartan worthy utter massacre.. Either plexi or regular glass coffee table in order here. Imagine how proper it could be, if possible a picture of the car going dwn the track when it blew it's bags & the Time Slip laminated inbetween glass layers, with 55 ////AMG RIP & date etched in glass like a tombstone...:
Edit: Contact/get Juicey63 to setup/manage large donations
Old 04-23-2014, 06:31 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Interesting... it somehow looks to me as if the piston seized before the rod broke apart.
I have had the exact same issue on my M119 V8 some years ago... It seized because of excessive fuel in the cylinder and as a result the piston got stuck and the rod broke apart, braking a hole into the block/oilpan.
Old 04-23-2014, 07:26 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
Crissus I think you're correct. A lean condition can cause the piston to expand and seize in the bore, leaving the con rod to be 'drawn and quartered'
Whatever happened, I agree that the carnage should be put on display somewhere to be admired and discussed.
Old 04-23-2014, 11:48 PM
blackbenzz's Avatar
haters crazy
Lol you have a motor?
ye athat would be badass!
Excessive fuel or not enough fuel? The log shows a lean spike and 28 degrees of timing. Dunno if that happened first or was a result of the carnage.
Should I start a new thread or just post what I find in here for discussion?
Worked on the car a couple hours tonight. Pulled the sc, condenser, radiator, drained fluids, etc etc.
Pulled SC and found something wrong...
Closer look of the new sunroof in the valley!
Ported heads seem to still have all the intake valves... Will have to wait until head comes off to see about the exhaust valves.
Hmm what do I do with this thing?
Remote mount supercharger!!!
More updates tomorrow night...
Old 04-24-2014, 12:11 AM
HeissRod's Avatar
Now that's how to keep S/C heat out of the engine bay!
Old 04-24-2014, 01:12 AM
Maybe you're onto something. I see a supercharger in the trunk with a belt spinning off the driveshaft and the outlet plumbed back up to the engine like the STS turbos. Ambient IATs?
Old 04-24-2014, 09:40 AM
blackbenzz's Avatar
haters crazy
lol
Patent pending lol
Old 04-24-2014, 10:33 AM
HeissRod's Avatar
But it has to have an electric clutch like Mad Max.
Old 04-24-2014, 12:16 PM
N_Jay's Avatar
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
I'm thinking that might take a little more than one tube of JB-Weld?
Old 04-24-2014, 01:42 PM
kittyandgary's Avatar
2003 SL55 AMG
Did a little leg (actually finger) work for you. About 10 5.5 liter Kompressor engines listed on e-bay from $2500 to $4K range. Here's one starting at $2500 with a 60 day warranty.
http://www.ebay.com/itm/MERCEDES-W220-W211-W219-S55-E55-SL55-CLS55-ENGINE-MOTOR-SUPER-CHARGE-TURBO-OEM-/171308046637?pt=Motors_Car_Truck_Parts_Accessories&hash=item27e2c1592d&vxp=mtr
Old 04-24-2014, 02:19 PM
blackbenzz's Avatar
haters crazy
Lol
Dammit, I only bought 1! I thought 1 and a little buffing should do the job. Now I have to go back to the store
Thank you. I saw that one with 155k miles. If I'm building a motor I already have a 55k block at Darton. Was just willing to do the labor to throw in a 55k block if someone wanted to see what it would hold.
Old 04-24-2014, 02:37 PM
N_Jay's Avatar
I am not sure what the "science" part is?
Are you expecting to extract some meaningful data from the destruction of an overbuilt old motor with unknown history without having some significant amount of measurement equipment on it during the failure?
Old 04-24-2014, 04:07 PM
blackbenzz's Avatar
haters crazy
Science as in testing a hypothesis. Hypothesis is 55k motor can hold more power than NA 55 motor. Perform an experiment to either accept or reject the hypothesis. The variables I listed... 1/4 mile, 60 to 130, dyno, etc etc.
By the way I log the runs. Plenty of data. I'm not sure what isn't scientific about it . People ask all the time "I wonder how much a 55k motor will hold?" So I offered to find out. No experiment is perfect especially with the budget we are talking about here. But it will be fun and give input on the subject. As far as I know nobody has tried.
If you have any other science questions let me know. I happen to be a scientist.
Old 04-24-2014, 04:18 PM
N_Jay's Avatar
Sample size is too small
Old 04-24-2014, 04:58 PM
blackbenzz's Avatar
haters crazy
Where did you see me state that the experiment was statistically significant?
N = 1 is > N = 0
Quick Reply: Anyone want to donate a 55k motor in the name of science?
