Bi-Xenon head light Adjustments?
I've tried searching but I can't find out if I can adjust my Bi-Xenon headlights on my 05 E55? The drivers side needs to be raised up for better vision. I'm not sure if I can adjust the low beam or if I need to have someone with STAR do this via programing? I've replaced the bulbs but I just need the light raised like the passengers side.
Thanks,
Mark
Thanks,
Mark
I had same problem. Put new bulbs in but the beam was face down. So I poped the hood and looked for the gears with the Phillips head on it. It deep in the rad support in top of headlight. Park car facing a wall with headlights on. Then turn the gear clock or counter clockwise with Phillips screw driver to move move beam up or down.
