How to fix a droopy eye
I've got an '04 with the bi-xenon headlights. The driver's side doesn't rise when the lights come on. As far as I can tell, it still moves left-right when I turn, but it stays in the "down" position.
What are my options for fixing this?
either replace the headlight to keep active xenon, or ditch the OEM lights for repos
LIGHTING E55 2003-2006
Philips D2S Xenon HID Headlight Bulb, Pack of 1 - Low Beam $44/ea
Philips H7 Standard Headlight Bulb, Pack of 1 - High Beam $6.50
E-Class W211 Passenger Side Headlight Assembly, Composite, Bi-Xenon, w/ Cornering Lamps, OEM #2118202461 $693.71
E-Class W211 Driver Side Headlight Assembly, Composite, Bi-Xenon, w/o Cornering Lamps, OEM #2118201761 $580.83
OEM E55 ~4000k Philips 9006 CrystalVision Ultra Headlight Bulbs (Low-Beam), Pack of 2 $10
OEM E63 (or E63 conversion) Philips H7 CrystalVision Ultra Headlight Bulb, Pack of 2 $27
Sylvania 2825LLBP Long Life Bulbs (city lights replacement) $3.50
for up and down its a different motor - you can access this from behind the unit.
the problem is slotting the new one back in as the ball shaped connector needs to be pushed into a cup that is inside the headlight.
I have pulled the headlight apart to replace the motor pack to fix left\right issue, then the other headlight up\down stopped working and I started looking into it, but then started working again... that was 6 months ago and has worked since.
It is true in the UK and other parts of the world that you can access up and down motor, but not in the US. The motor is sealed in in US models. You can take a look at the pics in my headlight rebuild thread
To OP, if the light is pointing downwards and you just want to adjust to the correct position and don't care about it actively moving, you can manually adjust upwards from the outside, there are some adjustment brackets behind the headlight that connect the headlight up/down to the motor. If you take off the caps, you can use a screwdriver to twist into position and just leave it at the correct height.
Step 12 in the link below shows the bar .. not sure if it can be adjusted without removing the bar. You could try turning the hex head shown in the picture .. it may just be stuck
https://mbworld.org/forums/w211-amg/...build-diy.html
thanks for clarifying that turbo
Nafis - you need to get the motor pack from a broken light, then replace by opening up the light unit. Theres some threads on this .
