Missfire
Missfire
When in idle, 3,5 cylinders keep shutting off and while moving 2/6. Plugs are newly changed. We switched the ignition coils and voltage regulators to see the difference, same, hence its not that. The injectors are fine too. Running out of ideas.
Any help would be deeply apreciated. Car feels like -100 hp
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
The wires to the plugs go bad often.
As i was replacing my plugs some 1000 km ago, i needed to replace a few of the wires. Also sometimes its the crank position sensor.
