Lowering W211 with Airmatic via DAS
Old 07-04-2004, 01:54 AM
stephens's Avatar
E55, F550, S600 Ducati 999
I have received many requests for the following info, so here you go.
Select E class
W211
Control Units
Chassis
Suspsension
Adaptations
Level calibration
Use the function keys as displayed to raise/lower the ride of the car until the desired result is achieved.
Note Voltages once vehicle ride height is set - in this case rear is at 3.25V which is out of spec
Check front height and measure
Check rear height and measure
Put jack under rear of car
Jack up rear of car body until rear voltage is at 3.00V -measure the difference in ride height from previous reading. Now RAISE the front this much and finish level calibration
Values to enter
DAS confirms values
New level accepted
Check new level values that have been stored
Checking vehicle level
Final stored values. The car thinks there is a load and allows rear to be greater than 3.00v and lowers the front to keep vehicle level. This is why we added height to the front after raising the rear on the jack.
This is only required if you want to really lower the rear.
Old 07-04-2004, 02:04 AM
stephens's Avatar
The final result
Old 07-04-2004, 08:00 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Since this method was different than what I had used in the past, I thought I would give it a try.
I must be lame though, because after doing all the steps (following them nearly exactly), and lowering the jack in the back (after disconnecting the SD), instead of the front coming down, the car raised its sagging rear...
One thing to note was that my preferred settings for the front resulted in voltages that were out of spec. So I had to raise the front a bit.
Might be because this car has a US-spec system, and it seems to know it is US spec, but couldn't find a way to version code the suspension for locale.
Anyone else get this to work on a US car?
-s-
Old 07-04-2004, 08:33 PM
stephens's Avatar
-s-
scorchie
This is a version independent setting. Tellme step by step how you are doing this and I will try and help you out.
This method does NOT work for ABC cars, but I worked out how to trick the ABC computer too on the new S class, but that's another story.
Old 07-04-2004, 08:34 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
Originally Posted by stephens
scorchie
Please share this as well
Old 07-04-2004, 09:27 PM
scorchie's Avatar
scorchie
Thanks for the offer! I'll do it again tomorrow and take pics and note values. Tonight is celebration night.
Stories about ABC would be cool too.
-s-
Old 07-04-2004, 09:37 PM
stephens's Avatar
-s-
scorchie, the most improtant issue is the order that you do things and keeping the values within acceptable parameters.
As for ABC we've got an S55 in right now having a full upgrade, so I'll do the same next weekend if I remember, but taking and posting so many pics is a royal pain in the behind.
Old 04-29-2006, 02:41 AM
crhait's Avatar
see sig
Select E class
W211
Control Units
Chassis
Suspsension
Adaptations
Level calibration
Values to enter
DAS confirms values
New level accepted
any way to get the pics back? please. want to take info to local mb tech.
Old 03-14-2010, 10:10 AM
elite001's Avatar
W211 E280 Advantgarde 2008 Full Options
the pictures are all gone, could anyone re-upload by any chance? and does anyone has any idea how much your dealer charge you for asking them to do this to your car?
Old 03-14-2010, 10:21 AM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
This thread is 4 years old! Way to bring one back frm the dead!
Old 03-14-2010, 10:26 AM
elite001's Avatar
Yes.. please please.. bring this thread back from dead please...
as my local dealer is an idiot, I told them about STAR, and what they keep on saying is "what's that.. what's that"
Please I really need a way to get my dealer understand about STAR sothat they can lower my car...
Old 03-14-2010, 10:29 AM
emoving's Avatar
Do a search, there is a DIY (do it yourself) thread. Print it and bring it in to them.
Old 08-28-2010, 10:32 AM
paultantk's Avatar
The photos are not loading
Old 08-28-2010, 12:21 PM
lightningfast7's Avatar
2005 E55
Old 08-30-2010, 02:06 AM
sorrentoguy's Avatar
Ford
someone should do a step by step with screen shots of how to do this, why are there so many secrets with our cars
I want to print it out and give to a local workshop who has the tools, but does not know how to do it
Old 08-30-2010, 02:20 AM
tgoss's Avatar
'13 GT-R AMS Alpha 9+, CLA45, E55
Just look up
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Quick Reply: Lowering W211 with Airmatic via DAS
