Camber out of spec Extended CPO Warranty Question
Old 09-29-2015, 06:49 PM
jpsamg's Avatar
2011 E63
Hi, my camber is out of spec for 3 of 4 wheels. Car has not been modified. Should the extended CPO warranty cover what ever is wrong to bring the car back to spec?
LF -1.9 fail range-0.05 -1.2
RF -1.7 fail
LR -1.9 pass range -1.0- -2.0
RR -2.4 fail
Rear Toe 0.29 fail range 0.30 0.54
Last edited by jpsamg; 09-29-2015 at 07:07 PM. Reason: car was aligned today, and it's still out of spec
Old 09-29-2015, 07:11 PM
Toadster's Avatar
2005 E55 AMG
usually things like alignment, brakes, etc (wear items) aren't fully covered...
if you have a bad ball joint, etc that's a different story - but you need to determine what the issue is first
Old 09-29-2015, 07:31 PM
jpsamg's Avatar
2011 E63
They did a visual inspection and did not see any issues, but I am suspecting something in the suspension is causing the car to out of spec. I know alignment is not covered, but if the car can not be aligned within spec and its stock shouldn't that be covered?
Quick Reply: Camber out of spec Extended CPO Warranty Question
