190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
No Spark !?!?!?
Old May 19, 2005 | 03:17 PM
srogers312's Avatar
No Spark !?!?!?
Hello Everyone,
After putting the engine back in my brothers 88 190E 2.3 I am not able to start the car. It cranks fine, there is plenty of fuel pressure, plenty of oil pressure, but no spark. I can literally stick a screwdriver in the plug from the coil that goes to the distributor and there isnt a spark! I have tested the starter and it tests ok. I have done the tests from the Haynes manual for the ignition system and it checks ok so far. Anyone have any clues? I really need to get this car running.
Thanks,
-- Steven
Old May 19, 2005 | 03:43 PM
SRDiver's Avatar
84 190E
you did plug in the CIS?
you did plug in the coil?
you did plug in the EZL?
Old May 19, 2005 | 04:53 PM
srogers312's Avatar
Of course ! hehe
Yeah . I went over everything and made sure it was all plugged in. I even checked the crank and flywheel sensors to make sure i didnt do the wrong ones to each. This is driving me nuts. I have taken the engine out twice in the past month and it ran fine after I put it back together.
Thanks,
-- Steven
Old May 19, 2005 | 05:07 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Ground strap? (just riffin' here)
Old May 20, 2005 | 11:08 PM
srogers312's Avatar
Ground Strap
Well if you mean the one that goes from the tranny bellhousing to the bolt around the inside of the driverside tire, I did it. I am not sure what good it does to ground out the tranny bellhousing, but thats how i had it hooked up before.
-- Steven
Old May 21, 2005 | 02:36 AM
vinamg's Avatar
The ground on the tranny is for the engine (starter, sensors, etc).
Check your Crank sensor (AC and resistance) and make sure that it has a snug fit to EZL. I've seen so many loose connections that cause no starting or stalling. Use a sharp tool to bend connector (sensor side) for a tight fit.
Old May 21, 2005 | 05:28 PM
srogers312's Avatar
Crank Sensor
Ok ill check into that. I believe its nice and snug in the hole but I will double check.
Thanks,
-- Steven
