190d 2.2
I now own an '84190d w/ 232k miles
The brake pedal goes all the way to the floor. You can pump it to build up a little pressure, but it doesn't last.
The a/c compressor, should it kick on when the ac is turned on at idle?
When the key is turned off, it still runs, where do I start my search???
Thanks for all, or any help... Bo
As for the engine continuing to run, check over at www.MercedesShop.com , search their Diesel section. I'm sure it has been covered there.
