190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Window Issues
Old Jun 16, 2005 | 12:46 PM
jballou's Avatar
1992 190E 2.6L
Window Issues
My driver side, front window won't roll down and neither will my passenger side rear window. It just started happeneing all of a sudden, and they both stopped working at the exact same time. I know the motors are good, in fact- the passenger rear window has a brand new motor in it. Any idea what this could be? I checked the fues, but that doesn't appear to be it.
Old Jun 16, 2005 | 12:58 PM
Justinius7's Avatar
I guarantee you its the fuse under the hood on the drivers side.
I bought the car witht he drivers window and rear pass window in-op.. went home, changed the fuse.. and just like that.. all fixed for .15 cents.
the drivers front and pass rear are on 1 fuse.... and pass front and driver rear by another fuse.
Old Jun 16, 2005 | 07:06 PM
dbenz's Avatar
1985 190E 2.3
If its not the fuses, then it sounds like its the switches. You may have to wiggle the switches, but if that doesnt work, then remove the switches and clean the pins with electrical contact cleaner.
