Oil Leak....
Oil Leak....
Have any of you guys seen those oil leak thingies you put in your engine. Do they work? Do they actually help stop or slow oil leaks? Are some better then others?
Thanks in advance
Thanks in advance
Oil Leak
I suggest you first find out from where the oil is leaking and attend to the leak the right royal way, as most of the leakthinges only increase the viscocitie of the oil and slow down the leak!
Thanks in advance
Thanks in advance
