Rims Size Help!
190E
Rims Size Help!
Hi guys!
Someone asked me "your car's Diameter, Holes, PCD, Offset, Center Hole" when I was going to order a set of rims. Can someone out there help me out? Cause I have no idea what the measurements are! What's PCD?
Thanks guys!!
Thanks guys!!
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
Here are the essentials that you need for buying rims for a W201 . . . most important, it has to have the correct hub (center opening) diameter since our wheels are "hubcentric" so wheels made to fit Audi, BMW, Porsche, will not work without an adapter ring. Second, the bolt pattern is 5 x 112. Third, the offset or ET (German) will depend on what wheels and their width. The stock 15" x 6" 15 hole rims are 49mm ET.
190E
Hey thanks for the info dude!
Just realised that I got some info on the rims I want.
Size: 17 X 7.0
Hole: 5
PCD: 98 - 114.3
Offset: 20 / 35 / 40
Ctr Hole: 67.1 / 73.1
Since previous rims had an ET of 49, which one do I use? 40? And the PDC and Ctr hole info, can the merc use any of those?
Thanks again!
Size: 17 X 7.0
Hole: 5
PCD: 98 - 114.3
Thanks again!
190E
Rim Details
hey guys,
Got some details on the rims I want.
PCD:5x112
ET:35
Center Hole:67.1
Anyone knows if this would fit the 190E? Let me know!
Thanks!
PCD:5x112
ET:35
Center Hole:67.1
Thanks!
