190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
hood liner
Old Mar 21, 2006 | 09:47 PM
kevin111's Avatar
190E2.6
hood liner
where can i get a new hood liner for my 92190e2.6? all parts store told me to go to dealer,and they charge 150bucks.
Old Mar 23, 2006 | 01:05 PM
RDM3's Avatar
1985 190e 2.3l
Try these places, I got mine for around $50 shipped, if you order over either $50 or $75, each place was different, shipping was free.
www.alloemcarparts.com
www.thebenzbin.com
www.thepartsbin.com
Old Mar 28, 2006 | 06:52 PM
SDR's Avatar
SDR
'99 C43, '12 C63, '13 E350, '14 Sprinter
The $50 pads are for the 2.3. The cheapest I ever found one for the 2.6 was at AutohausAZ.com where it was $110.
I feel it was worth it to get the full hood length covered.
Note that it's very hard to find the push rivets for securing the pad. I ended up using regular aluminum rivets for the top 6 and the plastic screw type fasteners for the remaining 4. The aluminum rivets actually look pretty cool and do a fine job.
Old Mar 28, 2006 | 07:39 PM
RDM3's Avatar
1985 190e 2.3l
Mine didn't have push rivets, it is glued to the hood, I used a 3M spray adhesive
Old Mar 29, 2006 | 08:16 AM
flowdrip's Avatar
1991 190E. 1973 DeTomaso Pantera
jtoutfitters.com has them for either $35 or 40 dollars.
Old Mar 29, 2006 | 12:11 PM
SDR's Avatar
SDR
True - even with the rivets you need to use the adhesive. There's a high-temp version (8090 I think?) that should do the trick. But in addition to the adhesive mine (a 1992) had six push rivets at the leading edge where the rubber trim strips are as well as four or six around the edges.
