Lets See Some w201's
the lap belts use the seat belt bolts in the floor. the shoulder straps bolt to the lap belt bolts under the back seat. all harness connections to body use existing seat belt mounting points on top of the existing seat belts.
front lap connection to b pillar
right shoulder strap connection to drivers side rear passenger seat belt latch connection
left shoulder strap connection to drivers side rear passenger lap belt connection
sorry, no pic of of drivers right side lap strap connection to latch connection on tunnel. tough to get a good shot of it. to install you can move the seat all the forward and up to allow enough room to start the bolt.
Very cool, thanks!. So with this set up, I see that you can still use the factory seatbelts as well, right?
Last edited by madwrenches; Dec 10, 2016 at 12:20 PM. Reason: OOPS should have blacked out plate number
