190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1990 190e 2,6 CEL codes
Old May 20, 2006 | 10:36 AM
2manyoldcars's Avatar
1990 190E 2.6
Hello, I have a 1990 190e 2.6. I built a homemade code reader and I can pull codes. The MB manual says it should have an 8 pin diagnostic socket but I have a 16 pin socket! Only pins 1,3,6,7,and 14 are used and pin 1 is the ground pin. I think the pins are: pin 3 - CIS-E (fuel injection)
pin 6 - SRS
pin 7 - A/C (HVAC)
pin 14 - MAS engine control
I read the following codes:
Pin 3 =13,16
pin 6 =3,6,8
pin 14 =4,11,13
The codes from pin 3 and 14 mostly suggest disconnected plugs and a bad oxygen sensor. The codes from pin 6 are for the SRS. However, the CEL turns on at lower rpms and goes off at higher rpms. Thus the codes from pin 6 do not make sense. Any ideas?
Old Aug 5, 2006 | 09:07 PM
JamesDean's Avatar
w126 82 300SD / w201 93 190E 2.6
how did you make a homemade code reader?
