Need Help Urgent!! Engine Matters
Hi there, I need some advice and help some expert out there. I have a 190E 2.3-16V 1990 Manual. Currently I am facing this problem:
The engine of the car can't start. Check from fuel distributor to ECU control unit. All working in good condition. It seems that there is no pressure from the engine. Can anyone there advice me what to do next. Thanks in advance. My email add: wanamulia@emobil.net
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
1990 2.3-16? Very rare since the 2.3-16 was phased out in 1988 by the 2.5-16.
Fuel, air and spark (in the proper sequence and amount) are required for combustion.
What and how have you checked the fuel distributor or ECU with?
Does the engine turn over, but not run?
Do you hear the fuel pumps switch on with the key?
Have you pulled the spark plugs and checked for spark?
