190E - '91, 2.3 - overheating
I just bought a used car: '91 190E. it has 160K miles on it.
I noticed that engine is overheating. It would reach little bit aboove 100 after driveing about 15 minutes. I turn on the heater at full speed to avoid the damage.
I also noticed that the cooling fan (next to the radiator) is on all the time. it is running at very low speed however.
I replaced a new thermostat. but problem is same. there seems to be no loss of coolant.
What should I do? Any suggestions?
1979 911SC, 2001 E55, 1999 CLK430, 1993 190E 2.6
Several folks have, it could be the radiator, temp sending unit on the block near the back or the clutch fan. Do a search for cooling harness (allows fans to come on early) and 190e Forums. There is a dedicated forum (190 revolution)just for that car that has plenty of technical advice.
good luck.
good luck.
