190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
190 2.3-16 problem
Old Oct 10, 2006 | 06:48 AM
Kum's Avatar
Kum
190 2.3-16 problem
HI,
A friend of mine has a problem with his 2.3-16...... The car has a poor performance at high RPM (full throttle). Does not work clean and a black smoke comes out of the exaust when throttle is applied.
I would be very greatfull if you can give any idea what the problem might be!
Thanks in advance!!!
Old Oct 11, 2006 | 04:06 PM
85Cosworth's Avatar
95 Bronco w/351 V8 & 2003 Mustang MACH 1
Piston rings might be shot (worn out).
Old Oct 15, 2006 | 09:13 PM
Hal9000's Avatar
There are any number of sensors which can fail and send the ecu into failsafe mode (full rich), which would explain the poor performance and black smoke.
Check the O2 sensor, Engine temp sensors, OVP relay, and throttle micro switches. Those are pretty common failures.
FWIW, this is becoming a more and more common problem with these cars, and it's a royal pain to track down since so many failures might cause the same problem. Does your buddies car also have idle problems? That's also pretty common and often caused by the same issues.
If everything checks out OK, have a mechanic put an exhaust gas analyzer on the car. It's always possible that the mixture needs to be adjusted.... especially if somebody tried to tune the car up themselves and messed with the eha.
Old Oct 15, 2006 | 09:49 PM
p rossi's Avatar
c32, 190e 16v turbo
what is the ovp relay?
Old Oct 17, 2006 | 11:49 AM
turbobenz's Avatar
over voltage protection relay . Its located behind the battery . check the fuse on top to see if its blown.
