190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Replacing Cyl head gasket 190e 2.6 gas
Old Jan 18, 2007 | 10:13 PM
jeremyspx's Avatar
Hello,
Just a quick question - do I remove the intake manifold bolts and separate it from the head before removing the head> The Hanes manual says to remove the entire assembly - head AND intake manifold but trhe looks like a heck of a job (and very heavy!) so I'm wondering if I should undi the intake manifold at the head instead.
Many thanks for your advice ASAP!
Jeremy
Old Jan 19, 2007 | 12:48 AM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
It can be done either way. Supposedly you save on not having to renew the intake gasket, but they don't cost a lot. Leaving the intake runners on does give you a bit of leverage when breaking the gasket seal on the head.
Since pulling the head is not a thing you do every day, regardless of how you take it off, once it is off I would remove the intake anyway to do a visual inspection of the intake side ports and maybe contemplate some machine work.
Old Jan 19, 2007 | 11:30 AM
jeremyspx's Avatar
190e cyl head gasket
Many thanks for the reply! I'll use the manifold as a lever until I have the head loose and then remove the bolts and remove just the head.
