1993 190e 2.3 auto trans question??
The transmition seams to be fine but recentley the shifter has started to be loose when in gear. I first realized it when I heard a rattle and upon investigation found the shifter loose. What could this be??? Is it easy to fix???
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
The shifter is adjusted from under the car. There is a ball joint that connects the shifter to the selector rod. The rod is fairly long and connects to a selector arm attached to arm and the starter inhibition switch. The pieces are held on with spring clips and lock nuts. With the car in neutral and the car safely up on jackstands, check the selector rod for movement and try to ascertain which parts are loose and/or worn.
of course, while your under the car, move the linkage by hand and you can tell if its just the bushing, or if there is something else.
http://www.mercedesshop.com/Wikka/W124ShiftBushings
