93 190E - 4th Gear disengages
runs like a top. Trans fluid clean and at the correct level. shifts as normal, but once it gets to 4th gear, it disengages and the engine free revs. I am forced to shift manually into 3rd gear and then it will pull fine (but rpm's too high for freeway). If i come to a stop i can put it back in drive and it will run through the gears again, but once i get to 4th the same thing happens.
I have had it on a hoist and have gone over every inch looking for vac leaks etc. everything is in order.
any thoughts or precedent??
thank you!
thank you!
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
Have the throttle cable, especially the adjustment at the engine side, near the microswitch, inspected. It may have slipped or been fiddled with.
