89 190e 2.6 Buying Help
....(192k!! should I even bother?)...Actually, it drove pretty well and is one of the better looking units I have seen for its mileage
Interior's got the usual air registers that don't operate well. Seems to be very common with these models. Must be all the plastic stuff that break. The heat worked surprisingly well. Per Carfax, its a one owner but can't rely too much on that.
Anyways, I always like to open the engine oil fill cap and look underneath it. To my dismay, I see a decent film of cream. Unless its just a fluke, this can be a sign of big trouble. The dipstick had no tell-tale signs but that usually the case.
Have any of you 190 owners ever worked on changing head gaskets? If so, any advise? Difficulty level? Etc.....Will it ever be the same after opening it up?
__________________
You will need a slide hammer to remove the timing chain guide rail pins.
If it's the first time you've ever done it, allot the whole day. Working on the 2.6L requires pulling the front radiator support. There's bound to be bolts or fasteners that are frozen or rusted, that will add time. The second time will be faster.
