Cold Start Valve Getting No Power......
The CSV does not get power during start-up (cold) thus it won't squirt fuel to the chamber. When the CSV is energized (voltage applied) it should supply atomized fuel but with no power coming to it, starting the car when cold is a problem.
Could someone knowledgeable in CIS-E help me find the culprit/s for this problem? I have some experience with CIS in Porsche cars. Any suggestions, recommendations, etc. is much appreciated. Thanks.
Tony
That leads to the ECU, which again seems to be working reasonably well in shirt sleeve weather. So, the downstream culprits may be the air temp sensor in the intake and it's cousin the engine temp sensor which are supposed to provide the ECU with the current meteorlogical situation. Also suspect the vacuum line to the CSV.
Thanks for your input regarding the problem I'm having with my car. My other problem is findng a reference manual with schematic or wiring diagrams. Based from your experience, how much would it cost to have this problem corrected by a Mercedes shop. A ball part estimate will give me a better feel whether to keep the car or not.
The car never had any major problem the last 19 years except the last 6 months. I really like to keep the car and spend a reasonable amount of money to keep it running. Appreciate your assistance.
Tony
