cant set idle mixture
I have 190e 2.6 with a few bad habits.
It hesitates when I press the throttle. It only does this if I lift off totally then re-apply. It does not matter if the car is at speed or stationary. and is fine to accellerate if the throttle is part depressed. It starts fine has heaps of power and loves to drink fuel.
I cant set the mixture as it goes from too rich to too lean all the time. A small turn will make little to no change then all of a sudden it will ge too far. It gives me a 82% fault code when I use the x11 but I don know what that means.I have been tryiong to set it to about %50 ish but I wont setttle and keeps going all over the place. I have used and extrenal O2 probe also.
It has new O2 sensor temp sensor. OVP. coil, leads, rotor, distributor cap, potentiometer, I have played with the eha and put another secondand one on it an then another. It goes really well heaps of power and it wouldnt vbother me much but it uses heaps of gas.
It also runs rough and will miss bady when you start for a few second then it goes away and settles into a roughish idle it will also incease and decrease rwevs at idle and this effects how badly it will hesitate off the line.
Any help would be great
