190E - 93 Cruse Control Does not work
2) Failed or intermittent cruise control acutator (under intake runners)
3) Failed or intermittent control stalk
5) Fuse No. 10 (red 10A)
6) Stretched speedo cable
7) Burnt brake light bulb(s)
What about the hall sensor behind the instrument cluster? Isn't that also a potential problem area?
I would like to know because my cruise doesn't work either. I have checked the switch, actuator, control box and fuse. All are ok but still no cruise and yes I do have ample fuel.
reubengeg
A stretched speedo cable, causing a jumpy speedometer needle will also "fail" the cruise control system.
The "typical" failure results from broken solder joints of the main circuit board of the amplifier. The remedy is to either replace it with a known good one or to take a low wattage soldering iron, open up the amplifier and then painstakingly touch all the solder pads so that the reheated solder can bridge any cracks.
