LS-190 patched and primered
1 Post
'07 Toyota Tacoma, '89 LS190, '07 Kawasaki Ultra 250X
Patched the holes in the trans tunnel and bulkhead supports.
Shot on some white primer. These pictures are a little dated I have since seamsealed.
Another coat of primer than I will under coat the bottom and then paint....white of course.
Also cut up the rear lower control arm pivots for more exhaust clearance, patched with some 10 gauge steel.
Welded in some supports from the crossmember to the framerails.
Made a PCM(powertrain control module) mount...
Made a little mount for the powertrain fusebox.
For anyone who forgot what engine is going in, here's an old pic
1 Post
thanks, ill post pics of the underhood when its all done(rubber undercoat, seamsealer, and paint).
Then wiring, radiator/fans,motor/trans installed with all accy's and starter.
Also take pics of the modified lower control arms to make room for the tie rods.
