new guy waterpump problem
First off, where did the hose connect to? Second, will replacing water pump solve everything?
note:
<--- not real mechanically inclined.
Thanks, John
There should be a thermally insulated (silver foil) hose that covers the wires from the alternator that protects the wires that run from the alternator to through the firewall from the exhaust manifold heat.
very easy job to do, just take off everything in front of the water pump to get to it and swap out (remember to drain ya water :P otherwise you might get a bit wet)
that hose is an overflow pipe (make sure you get the correct water pump for it, autos dont have this if i remember correctly, also remmber to plug up one of the holes with the bolt provided... basically just make sure you put the water pump in that has the same configuration as the one your taking out)
(sorry if this sounds patronizings, figured i would say everything i learnt when replacing mine just in case you are as ill educated on cars as me :P)
anymore questions head over to http://www.mercedes190.co.uk very knowledgeable and friendly guys there
best of luck fixing it
should be very cheap and easyChris
