Radiator Flush
The other day I took my 190e (2.3) to a shop (not MB) to get the radiator flushed. Preventive Maintenance !
They flat out rejected to do this service because they said they've had too many problems doing this
What exactly seems to be the tricky part in doing this?
What coolant does this MB car require?
I'm not mechanically ignorant so I'm considering doing this myself.
HELP!
Flushing a W201 cooling system is no different than any simple system.
Mercedes uses a citric acid based flush, just like everybody else.
There are two coolants to consider using in the W201, the Mercedes labled jug or the Zerex G-05, diluted to 50% with distilled water. You many notice that the two jugs, except for the color of the plastic, are identical . . . as is the coolant. Care to guess why?
I see you're the proud owner of 2 190e's.
What do you like about the car?
Me, personally I't my first benz, but already the best car I ever drove and it's 20 years old !!!
It feels so solid. Has enough power. Gets good gas milage and looks so classic.
