190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Radior Flush
Old Dec 14, 2007 | 06:57 PM
tunayballa's Avatar
1989 W201 1999 W210
Radior Flush
Hi all,
I'm in need of a radiator flush and would like to do it myself. After I drain the radiator, do I just refill from the fluid chamber in front of the battery?
Old Dec 15, 2007 | 08:44 PM
reubengeg's Avatar
There is another drain on the right side of the engine block. You should open it an flush out the water in the engine block as well as the radiator.
reugengeg
Old Dec 17, 2007 | 12:29 AM
tunayballa's Avatar
1989 W201 1999 W210
Thanks reugengeg, anything else I should note before I flush?
Old Dec 17, 2007 | 11:58 PM
reubengeg's Avatar
I don't know how others flush the coolant system but I remove the thermostat then button back up, Add the flush solution. After the engine runs a while open the block drain then the radiator drain until water turns clear. Be sure to use MB approved coolant, Do not use the green stuff,
