190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
How many quarts of oil in 2.6?
Old Jan 6, 2008 | 03:28 AM
LittleB's Avatar
1993 190E 2.6
I'm changing the oil for the first time in my new 2.6 How many quarts does it take? I can't get a manual yet :s
Also, anything I should know about changing the oil? Any special tricks?
Old Jan 7, 2008 | 12:36 AM
tunayballa's Avatar
1989 W201 1999 W210
6 quarts, nothing special on changing the oil. The filter is behind the air filter chamber and remove the splash guard below the engine and the oil pan will be there.
Old Jan 11, 2008 | 12:54 AM
LittleB's Avatar
1993 190E 2.6
Thank you
Old Jan 11, 2008 | 11:54 AM
PhilipM1's Avatar
1993 190E 2.6
my car only takes 5 1/2.
Old Jan 11, 2008 | 02:40 PM
LittleB's Avatar
1993 190E 2.6
I already did it and put 6 in :o Is it a bad thing to have a bit too much?
Old Jan 11, 2008 | 05:36 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Just stay within the dipstick plastic markers.
Old Jan 15, 2008 | 01:05 AM
DarkCreep's Avatar
190E
You should be fine. Did you go full synthetic?
Old Jan 15, 2008 | 04:17 PM
PhilipM1's Avatar
1993 190E 2.6
I do a Syn mix. I also get my oil done once a month. and it always come out pretty clean. Is it a lot better to go full syn?
Old Jan 23, 2008 | 02:42 PM
itz16v's Avatar
89 300ce//// 86 190e 2.3-16v//// 12 CLS63
What about the 2.3-16v how many quarts of oil?
Old Jan 23, 2008 | 03:21 PM
MTI's Avatar
MTI
The TOTAL (fresh engine or rebuild) rated capacity is 5.5 liters (5.8 qts),
For the 8 valve M102, in case anyone is interested, it's 5.0L (5.2 qts).
When doing a filter and oil change, you're not going to get all the oil out, so go easy on that 5th and 6th bottle by checking the dipstick.
Old Jan 24, 2008 | 07:29 PM
itz16v's Avatar
Mahalo for the tip brah.
Old Mar 9, 2009 | 06:50 PM
brucehoward's Avatar
190E 2.6
My 2.6 fills up with 5 quarts.
Old Mar 11, 2009 | 02:23 PM
SLOPESTAR's Avatar
99' E320 4MATIC ESTATE / 92' 190E 2.6
My 92' 2.6 goes 5000m between changes. Requires 5.5 quarts and usually 500m before, it runs a wee bit low on oil. No smoke, low compression or leaks, just burns a bit over time. She just keeps going. 165,000m going strong.
