Replacement Dash Speakers
1995 E320 Special Edition
In process of removing dash to replace the heater core and I need to know where or who has replacement speakers for a 93 190E? The originals are shot and this is a perfect time to replace and upgrade from the stock speaker. Thanks in advance!!
be careful which speakers you buy. If the have built in tweeters, you will encounter clearance issues with the grill with many brands. Replacing the speaker wire is likely a good idea as well since it is hella old and high guage.
I installed Infinity speakers with tweeters built in to speaker with no problems.
1989 W201 1999 W210
how to remove the dash speakers? There are grilles on the dash with a screw. Unscrew and pop the cover off...the speakers are easy for removal. You don't have to remove the dash to get the speakers out.
