190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Instrument Cluster gauges
Old Apr 11, 2008 | 12:57 PM
m1sandman's Avatar
1987 MB 190e 2.3-16
Howdy all,
Just picked up an 87 2.3-16, and this afternoon when I got into it, the fuel gauge, coolant temp, oil pressure, oil temp, and volt meter all stayed on 0. They were working this morning and last night without a problem... I'm guessing fuse, but I can't tell which one it might be. Anyone got any suggestions?
Thanks,
Steve
Tampa, FL
1987 MB 190e 2.3-16
2000 BMW 323iT Sport
2000 Mazda 626 ES V6
Old Apr 11, 2008 | 04:55 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Just for laughs, give the dash a thump and see if it affects the performance of the gauges. If it does, then it's likely you have a bad ground contact to that side of the cluster.
Fuse #9 is for the whole cluster.
Old Apr 12, 2008 | 01:02 AM
PhilipM1's Avatar
1993 190E 2.6
Im going with fuse!
That is usually the casue the all of those going bad at once.
Old Apr 12, 2008 | 03:58 AM
tunayballa's Avatar
1989 W201 1999 W210
Talking
Since you are there, you might as well replace all the fuses. Clean off the connectors with a tooth brush and put new fuses to ensure everything works as it should. Fuses may look "ok" but I bet if you just move fuse 9 around, it may work. While you drive though, you'll see the gas gauge flicker up and down somewhere down the line. Everyone knows what I'm talkin about.
Old Apr 12, 2008 | 05:05 PM
PhilipM1's Avatar
1993 190E 2.6
14+ yr old cars FTW
