190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Wood trim removal
Old May 9, 2008 | 05:17 PM
onodon's Avatar
1997 C36
Wood trim removal
I searched for about half an hour and I cannot find a thread specific to the 190e on how to remove the wood trim plate on the center comsole. Any help is appreciated. I am trying to replace one of the power window switches.
Thanks,
Old May 9, 2008 | 06:02 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
The shifter surround wood trim piece is removed by using a wedge, like those plastic putty spreaders, at the bottom of the piece (side closest to rear seats) and slowly and gently lifting up. Once lifted, start unplugging the switches as they are exposed until you get to the mirror control, hazard and fader, then you can lift it up.
While you're in there, might as well change the bulb that illuminates the shift lever selector.
Old May 9, 2008 | 08:24 PM
onodon's Avatar
1997 C36
Thank you, it worked perfectly. I appreciate your response.
Regards,
onodon
