190E Horn not working anymore.
1989 Mercedes Benz 190E 2.6L
I have a 190E 1989 and the horn on the steering wheel has stopped working. Does anyone know which fuse applies to the horn? I can't seem to find anything in the cars manual. Thanks!
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
Fuse #11, white, 8 amp
If the fuse is good (test with ohm meter, not visually) then your next suspects are the horn(s) themselves, which is common, or the horn switch on the steering hub.
You can easily test the horn(s) by using test clips to 12VDC+ to the terminal.
