How to adjust idle speed (2.6)?
While in P or N it idles at about 750 rpm, and while in D at about 550 rpm. It really rumbles at stoplights. How can I adjust it, and what speed should it be at?
I havent heard of actually adjusting the "idle" You can change the air/fuel mixture. That is in the center of the air box, there is a hole on top. Stick a hex key in it and turn it 1/4 a turn at a time till you have the right adjustment. Some of them, like mine, are actually caped off and I cant adjust it without grinding down the cap. You can remove your air box completely to get a better view and see if yours has been capped also.
With all that being said, I dont recommend adjusting this. Take it to (MB/your mechanic) have them set it at the right mix.
Good luck.
I have a 190E 2.6 and it idles at the same speeds as yours. My 95 E420 did and so did my 2001 CLK55.
I think it's OK, what's the issue? Is it stalling?
"Some M103 engines develop a slight hesistation off the line when the engine is cold. They may also cold start instantly and then die, but restart easily and then continue to run. By adjusting the fuel distributor lower chamber pressure to 0.45 bar (6.5 psi) instead of 0.4 bar (5.8 psi), both of these symptoms tend to disappear. The car also seems much livelier off the line and idles better when cold.
You are not really richening the mixture when making this adjustment. Instead the adjustment is compensating for basic wear and tear and any unmeasured air leaks that have developed over the years. You will need a CIS fuel pressure gauge to measure and adjust the fuel pressure. If you reset the EHA, the idle mixture should also be checked and adjusted. Refer to the factory repair info on making this adjustment."
I showed this to my new indy tech the first time I took the 190 in and he said, of course, we do this all the time. He turned the knob 1/8th of a turn and it measured spot on at 0.45 bar.
The car runs MUCH better now and idles at just over 750, about 800 after warm up.
I do have that w124 owner's bible, it's a pretty good read
Thx,
P.S. Thanks everyone for your replies.
