190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Flex disk replacement
Old Nov 21, 2008 | 09:55 PM
Pasha95's Avatar
'95 c280 '93 190E '07 C230
I need to replace the front flex disk on a '93 2.6 and I'm wondering what size wrench I need for the nut on the end of the front drive shaft?
Thanks for "someone's" help.
Old Dec 3, 2008 | 08:28 PM
sun111's Avatar
190e 2.3
put whole car or rear on jack stands remove trans mount bracket, put trans in neutral, remove each bolt at 6:00 o'clock by rotating driveshaft, slide driveshaft back 1.5 inches pullout flex disk toward 2 o'clock If I remeber right, put new disk in at 2:00 and reverse procedure. you might have to remove exhaust mount.
Old Dec 6, 2008 | 11:25 AM
Pasha95's Avatar
Flex disk
So you are saying that the disk can be replaced without removing the front drive shaft from the universal joint?
Thanks for your help
Old Dec 8, 2008 | 02:18 AM
sun111's Avatar
190e 2.3
yes, just replaced mine when I did trans modulator and trans mount, do not remove axle. It's not that hard.
Old Dec 12, 2008 | 12:59 PM
Pasha95's Avatar
Flex disk
Thanks for your reply
