190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Automatic Transmission
Old Sep 2, 2009 | 01:01 AM
Benz Sage's Avatar
1986 190E 5 speed & 1986 190E Automatic
Greetings and Salutations
I have an 86 190e Automatic and seek advice. When I first purchased it, the transmission would shift sporadically, without rhyme or reason. Trouble shooting it I figured the modulator valve was the culprit. I changed fluid and filter, and filled to the correct level. After turning the Modulator valve adjuster counter-clockwise, increasing hydraulic pressure, correcting the Ignition Timing, the performance improved. I also swapped out Vacuum hose connections about the engine with High Temp silicone and reset the Bowden Cable and now it shifts reasonably and I can accept its performance.
The only gripe is the second to third shift is lethargic and doesn’t shift crisply as does the rest of the RPM shift points. Is this a symptom requiring the replacement of the K-1 valve of which the part number and instruction of installation is documented within the bowels of this forum?
Benz Sage
Attached Thumbnails Automatic Transmission-benz-sage-s-86-auto.jpg   Automatic Transmission-benz-sage-s-86-5-speed.jpg
Old Sep 13, 2009 | 11:16 AM
relmonte's Avatar
1991 190E
Ask this question on 190rev.net, you may get a quicker answer or response.
