190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Metallic Sound when putting in Reverse
Old Mar 26, 2012 | 02:36 PM
mbpk190's Avatar
1991 190E 2.3
Hey there,
Recently bought a 1991 190E 2.0. Whenever I put it into reverse there is a very audible metallic sound (sounds like when you hit two heavy metal pipes together) coming from the rear of the car, did a little reading and I think it is the flex disc. What should I do?
Also the car seems to bog down and shifting is a bit slow when on AC (seems to be a slight delay for a second without AC). Overall the car seems to drive very good! Has 138K on the odo, Japanese import into Pakistan.
Anybody with suggestions as to what other maintenance is required? I used to own a 1991 230TE in Abu Dhabi which I sold after 6 years without any major maintenance.
Old Mar 27, 2012 | 02:27 AM
DRACO's Avatar
85 911 Targa
Probably the drive shaft flex disc, basically a rubber bushing that absorbs the shock of getting into gear of the trans, when this breaks apart shift into drive or reverse is very abrupt.
Old Mar 27, 2012 | 08:18 PM
mes419's Avatar
2015 C300 4MATIC, 2003 CL55, 2009 C300 4MATIC
I agree with DRACO, My car does the same exact thing, but when it goes into drive and reverse.
Good Luck!
Old Apr 9, 2012 | 05:28 AM
mbpk190's Avatar
1991 190E 2.3
cheers everyone! yes i had the mechanic look at it and he says it is the problem will get it fixed.
