Questions about 190e Customization
1. The 300e brake conversion will fit under Monoblock rims?
1a. Are there different versions of monoblocks?
2. Is this car lowered, or do the new rims and tires fill out the wheel wells better?
http://germancarsforsaleblog.com/dec...-190e-2-3-16v/
Thanks for the help
Thanks for the help
There are different Monoblocks in the sense that most are 18" but a very few are 19 (almost impossible to find). They all look the same. In an 18x8.5 ET31 monoblock, you can fit a 4 piston 355mm BBK. If you had the measurements from the 300e, that would be much easier to answer your question.
Generally speaking, you can fit 335mm rotors into a 17" wheel, 355mm into 18" wheel, and for the big guns (ie 390mm) you need 19-20" wheels.
To answer your second question, it's been lowered and the wheels are 18" monoblocks. I can imagine that there was either lots of fender rolling, or lots of rubbing occurring on a regular basis with that setup. I'm sure it would be feasible to get that setup working properly though.
I've talked to a few owners so far and I think I am gonna go with 18x8.5 and 18x9.5 monoblocks with H&R coils. Doesn't sound like I'll have rubbing issues.
