190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
w201 interior swap
Old Feb 19, 2013 | 12:54 PM
ruzhkata's Avatar
Mercedes Benz C280
w201 interior swap
Hey I just got a w201 that has pristine looking leather interior, however it's blue. And blue is not my favorite color. I have access to a w202 all black interior. Has anyone ever swapped a w202 interior into a w201? Will it fit? How does it feel after? I"ve seen the video of that c36 w201 but these russians can do anything. I need some tips and if possible a DIY guide. Please help
Old Feb 19, 2013 | 04:37 PM
MercedesDad's Avatar
New, old Mercedes and REAL AMG's.
Blue interior? I'm not sure but have never seen a blue interior in person, so I would think it might be rare (?).
Old Feb 19, 2013 | 04:54 PM
DocWalla's Avatar
1991 190e 2.3
I second that, I would check the vin plate (and the plate on the front under the hood with the holes in it) and see if its original.
Old Feb 20, 2013 | 02:45 AM
ruzhkata's Avatar
Mercedes Benz C280
yep car is all original, vin number and the color code plate all check out. I can sell it to the right buyer since it's rare lol. anyways i'll most likely be just replacing the steering wheel, and the woodgrain panels with faux-carbon-fiber. For some reason i want to get white dials in there as well.
Old Feb 23, 2013 | 09:17 AM
dartony's Avatar
190 D 2.0
Hi,nop you can`t fit an 202 interior in 201 at least no straightahead you have to do a lot of cutting and is better its own interior, instead you can dye it ,clean it ,sand it,clean it very well an then a new colour , you need to sand ad clean it several timesif you want to have a good job and most likely you like it black,don't you
Old Feb 23, 2013 | 07:49 PM
ruzhkata's Avatar
Mercedes Benz C280
I gave up on that idea of swapping the interior. most likely will swap the engine of a c36 along with the exhaust system. not sure if c36 amg can run on regular 5 speed manual transmission though
Old Feb 25, 2013 | 02:52 AM
DocWalla's Avatar
1991 190e 2.3
Not sure if it will bolt up to the tranny (might need to fit a machine shop bill to getthe an adapter plate of some type done) but I have heard rumors of a 3.6 version of the 201 that was done by brabus, from what I gathered, its the bottom end of a c36 mated to the jetronic fed 300E top-end. Something about using a c36 head gasket and everything is plug and play with some a/f mixture adjustments, may be a lot easier then trying to install the fuel system from a c36?
